SOURCE: Frigidaire Affinity Front Load
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at [email protected] for futher info
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that
is activated at the end of the wash cycle for the machine to advance to the spin cycle.
This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies
that the auxiliary switch cannot be activated and the door lock and
switch assembly is faulty. Replaced the door lock and switch assembly
(part #131763202) to address the issue.
Disconnect power to the
machine. Open the washer door then look for the retaining hoop securing
the door seal around the lip of the door opening. Stretch the retainer
spring of the door seal retaining hoop then remove it.
Carefully
peel off part of the door seal from the lip of the door opening near the
door lock and switch assembly. Remove enough of the door seal to gain
access to the door lock and switch assembly.
Remove the screws
securing the door lock and switch assembly to the front panel. Once the
screws are removed, lift the door lock and switch assembly then pull it
away from the front panel.
Take the door lock and switch assembly
out of the machine. Disconnect the electrical connections then
connect it to the new door lock and switch assembly.
Put the new
door lock and switch assembly back into position in the front panel and
secure it with the securing screws.
Properly put the eased part
of the door seal back over the lip of the door opening then secure it
with the retaining hoop.
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
