Nikon Coolpix 5700 Digital Camera Logo
Posted on Apr 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem in reading memory cards of NIKON D80
I tried to read the memory cards in my Notebook but unable to do so. Even having the SD memory slots. I can copy the pictures from the memory cards and if I try to open directly pictures then says INVALID FORMAT and afterward those pictures will lost from the memory card and even I can not see those picture in Camera also.
I am using HP Pavilion dv6000 Notebooks. Can I get the solution? But able to read the memory card of Sony CuberShot.
Anonymous
Level 2:
Novelist:
  • Expert 181 Answers
  • Posted on Jan 08, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
181
Questions
0
Helped
86311
Points
305
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
My d80 keeps reading error, i have tried adjusting lense and changing memory cards, don't know what else to try
What is the error message? If it is ERR then ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work then it will need to go call Nikon digital 1-800-645-6689.
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
2answers
When i connect my d80 to my pc it freezes
You can try to a SD card adapter for the USB slot and download without the camera. The adapter is pretty cheap and sometimes comes with the SD Card.
The PC reads the camera as an external drive, make sure your PC and OS is up to date.
2helpful
2answers
I have a Nikon D80. A few months ago, the SD card would not stay in the slot, then for no reason it started working normally agan. Now it won't stay in again. It doesn't catch when you push it in, it just...
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Memory card won't stay in the slot, won't read.
service camera at Nikon. mechanical SD card lock failure
2helpful
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
D80 : Memory Card Fit
I know that an SD card could lose it's little lock if it is damaged, the worse place is in the slot where it would block another card from seating fully. (don't force it) Even in a padded case if the sd cards are sliding around loose the can get damaged or even get dirt, lint or fuzz in the "lock".  If this has happened don't probe around in there, if you do there may be further damage done, that one a camera repair shop might be able to do or you may have to send it to Nikon for repair.  Don't have the camera on or even the battery in if you can't resist trying and don't stick anything metallic in the slot.
randy320sgi
2helpful
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
2answers
Nikon D80, memory card jammed
Can it be pushed into the slot any farther?
3helpful
4answers
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
