https://dodgeforum.com > ... > 3rd Gen Ram Tech
I cant find my orifice tube location a 2007 dodge ram 1500 with a 4.7 engine. Might be better to put this in the 3rd gen Ram forum instead of 2nd gen Dakota.
drain radiator take upper and lower hoses of the radiator then disconect transmission cooler lines from passenger side of radiator you may need a disconect tool then remove 4 bolts that hold shroud and radiator.
disconect overflow tube pull shroud back so you can lift out radiator dont loose two rubber bushings on the botom.when you put in new radiator be careful not to beat it up with the shroud then reconect everything good luck
you sure its not the breather tube for the t-case. about 3/8 hose if it is. the vacuum lines for the 4x4 are small plastic lines. red, blue, yellow, etc. think there are four of them
