Question about Garden
Morrison weedeater how do i get the cap off to replace nylon strings it doesnt pop off anyway do i need a socket wrench to get it off?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Posted on Oct 08, 2013
SOURCE:
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to know how to replace string on weedeater gas blower FL1500LE
The Weedeater FL1500LE is a 23cc 2-Stroke Gas Blower and does not use string. It only uses air.
Mar 31, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
One of my wipers has free play on the driver side, when i turn them on the driver side wiper doesn't respond.
Don't know if you still need help with this but I just had the same thing happen to mine after the drivers side was frozen to the windshield last week. All you need is a flathead screwdriver( butter knife) and a socket wrench (any adjustable wrench). Pop the hood and there is a cap on the end of the wiper nearest to the engine. With the flathead screwdriver pop off the cap and use the proper bit to tighten the nut with your socket wrench. The problem seems to be that when too much load is placed on the wiper the nut will slip and the blade will no longer have enough tension transferred from the wiper motor to the blade resulting in sporadic movement. Good luck worked for me oh and from what I have read once it has happened once it may happen again just repeat until the bolt needs to be replaced.
Feb 07, 2011 | 2004 Mazda 3
I have the Morrison BC 260B S2 Weed Trimmer but I don't have any instrucions for its use. I need to know what the mix of 2-Stroke petrol is and its general operation. This is not mine and the owner doesn't...
I have one of these. The mix is 25 to 1. Before starting use the primer bulb to get fuel through; it says to turn the choke to limit the flow, but I've found mine starts easier with the choke open. To start, flick to on/start position, hold the (safety switch?) flush with the spine, and give it a yank.
Sep 04, 2010 | Homelite Mighty Lite Lawn Trimmer
Cant get the cap off to replace the string on a troy built trimme
The cap just pulls off but yes it will be tight if its the first time you have ever removed it to replace the nylon string. Use a small flat screwdriver to lever under the edge of the cap and pullng at the same time but be carefull not to break the plastic surround
Aug 02, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cannot get spool out of Poulin Weedeater Lite
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 27, 2009 | Poulan Garden
Have weedeater but no manual to read on how to restring to line
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
Jun 10, 2009 | Troy Garden
Can't get the head off troy-bilt weedeater to replace the line.
Threads are left hand. Hold the black wheel and use large plier or pipe wrench to turn the knob cloclwise
Apr 28, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
194 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
