SOURCE: Maytag electric dryer will not run
Just like the other tech. said, it is most likely your belt or a bad motor. The belt is a pain in the neck to replace because the top, the back and sometimes the front need to come off.
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
SOURCE: Maytag dryer LDE512, 20 years old. Buzzer is
Motor centrifugal switch may be stuck. End of motor where switch is may be full of lint
SOURCE: I have a Maytag dryer
Hi Buzzer comes on because the control senses that the door is
not closed and won't start the cycle. This issue is caused by door switch-latch
assembly (part#6 and part#9 in this diagram) that is bad and should be replaced.
Hope this helps...please post back for further assistance. Daniel
SOURCE: I have a Maytag MDE9206AYW
No unfortunately the buzzer volume cannot be adjusted, the only option is literally disconnecting it inside the wiring compartment where the dials are.Let me know if this helps
Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
