Would not turn.I took the back off and removed the snap ring but could not figure out how to remove the bearing . The bolt holding the pully on seems to be stripped since I had a hard time removing it. Is the bearing covered under warranty and do I need a special tool to remove and install it. Thanks for your help.
Mine wore a groove in the front half of the outer drum.
To change that bearing you speak of, you must replace the rear half of the outer drum and it is $400 for the part.http://www.appliancepartspros.com/Applia... Mine will need both halves... http://www.appliancepartspros.com/Applia...
This thing didn't even last nearly as long as an old Kenmore top load washer.
