SOURCE: Setting time and date
here is the link to the user manual.instructions to do that should be in there.
User Manual
SOURCE: Remote retrieval of messages
Call your phone number. After the greeting is finished and you hear the beep to leave a message push 123 on a touch tone phone and you will be given a list of things you can choose to do including listening to messages. 123 is the default security code unless the security code has been changed. Since you dont know how to retrieve messages Im assuming the default security code has never been changed.
If 123 is not the default security code and you dont know what the code is, you can change your code in the setup menu. You get to this by pushing the stop/set button on the answering machine and holding it for a couple of seconds. Since GE doesnt offer a downloadable manual for the 29878GE1 you should probably take a look at the manual for the 29875GE1 which is basically the same model with the addition of a digital message counter. Hope this helps.
SOURCE: Can I access the GE 29869GE2 Digital Messaging
Do you know the access code?
If so, it appears from the manual that you can. I would upload the manual (if it's not on the FixYa site) but the FixYa server will not let me. You can find it on the GE website under the links for Consumer Electronics.
SOURCE: instructions ge digital messaging system 29888GE1-A
I followed this instructions
you hold down the play and greeting button....speak when prompted... then let go of the buttons. voila... recorded
And it works ok!!
Thanks a lot!!
SOURCE: Need manual for GE Digital Messaging System, Model
You can download the manual in PDF format by clicking this link.
Hope this solves your problem. Thanks for using FixYa.
