Probably a perished vacuum hose has collapsed or blocken, a bugga of a job replacing them. Check the ones at the engine first, it will be a small hose that disappeared throughthe firewall.
check breaker first it will run with the breaker tripped but it wont heat so turn off and on then check dryer for heat.dryers have a thermal fuse when they go bad it wont heat they are located on the element cage and are smaller than the thermostats.and if that is good then most likely element.but it usually helps to know what brand?
