SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
SOURCE: Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
SOURCE: Amana washing machine (ALW880QAW). Does not work
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
