Look on line for a power supply for the tv. Buy it. Ship it to your home.
Place the tv face down and remove the cover panel off the back after unplugging the tv from the power.
Remove the part that is the same as the one that you ordered and replace it with the new part.
I have done this several times before and if you get stuck then go to YouTube and see if there is a video about the job there it's very basic.
The power supply module inside TV is damaged. Without proper knowledge and instruments, better call service company.
SOURCE: coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
SOURCE: The unit won't turn on
There is no solution but to buy a better player!!! Axion and Phillips have done well for me as International players, and has JWIN.
