There is probably a software driver that needs to be downloaded to interface between the magic wand and your computer. Go to the manufacturers web site and see if they have one.
If you want to check a key of an already installed program on your computer there are freeware keyfinders on the internet http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping. it could read something like this
MB8VG-KB3VC-D236C-H82YB-KYRY6 Office Professional 2010 after an upgrade trial you might need to reinstall because its a trial but if you have purchased the key you might not if you do have to do a reinstall use the magic belly key finder to locate the serial key
1st You download Webcam Driver. I have windows 8 and need to install logitech quick cam v11.1. How doi do this? After this install the Webcam driver in the system. Installation of Webcam Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager s Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
the drive has developed some bad sectors on it click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer then defragment your hard drive
or you could download partition magic when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partitionPartition Magic 8.0Partition Magic 8.0 http://www.filehoo.com/download/Partition-Magic-8,0.aspx
To scan something from your printer to the computer you should have the hp solution center installed in your computer
double click and open the solution center
place the document or the picture that you wnat to scan on the glass bed of the printer (the text content should face towards the glass)
now click on the scan document or scan picture button on the hp solution center
a window will come up click n the scan button
then a window will come up showing the preview of the scaned document or picture
click finish to finsh the scan
now you can view your scan by going to the MY SCAN folder in MY DOCUMENTS
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
