It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
The headset volume is turned to zero. Hit the "menu" key on the headset and it should take you to "ringer setting", hit select for the ringer volume and turn the volume up. Not very intuitive but that should get you going!
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Browsing through the menu should eventually show you the page for setting the ringer.
Choose the menu by pressing the button, then jsut use the arrow key for stepping through it until you find the ringer menu item.
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
