Question about Patton SmartNode 4960 T1/E1/PRI VoIP IAD - 24 Channels Router (SN49604E24)
Configuration factory reset - Patton SmartNode 4960 T1/E1/PRI VoIP IAD - 24 Channels Router (SN49604E24)
How to reset password for motorola surfboard cable modem sb6141
There is no password on the SB6141.
There are no user configurable options. Any configuration is changed through communication with the CMTS.
When you access the modem (192.168.100.1) all you can do is monitor the signal quality and certain log entries.
NOTE: the "configuration" page allows you to reset the factory defaults and to restart the modem. IF you reset factory defaults this note applies:
Resetting the cable modem to its factory default configuration will remove all stored parameters learned by the cable modem during prior initializations. The process to get back online from a factory default condition could take from 5 to 30 minutes. Please reference the cable modem User Guide for details on the power up sequence.
Aug 24, 2014 | Motorola Computers & Internet
How to configuration hard drive to factory default
Step 1:
Which operating system ?
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Mar 16, 2013 | Acer Aspire 5500 5570-2609 Laptop
Factory reset and now my internet will not work
May be you are having problem with your internet configurations. Try obtaining new configurations from your service provider
Nov 28, 2012 | Cell Phones
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
I changed the default password, and I forgot it. How can reset the password, without lost the configuration?
There is no way to recover the password unless you reset it to factory defaults. This would mean losing your current configuration. I would try to guess everything you can possibly think of. If you still can't figure it out you need to reset to factory settings. To reset factory settings there is a button on the back of the router that says reset. Hold this down for 30 seconds and everything should be reset.
May 17, 2011 | Zonet (ZSR0104UP) Router
Lost my passphrase
You'll have to reset your router to factory defaults and the configure it all over again.
To perform the factory reset, press and hold the recessed "RESET" button on the back of the router for 15 to 20 seconds. This will return the router back to default factory settings.
Use the web interface or the software that came with the router to configure the router again with a passphrase and change the administrator password.
For more detailed instructions, read the user manual.
Dec 30, 2010 | NetGear WNR2000 Wireless Router
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
I need to rest my router
YOU CAN RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. Use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
CreativeTECH
Nov 16, 2010 | NetGear Computers & Internet
Forgot username n password
you will need to reset the unit by depressing the reset button with a pen on the back of the unit.
Jan 26, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Patton SmartNode 4960 T1/E1/PRI VoIP IAD - 24 Channels Router (SN49604E24) Logo
24 people viewed this question
Top Patton Computers & Internet Experts
Alun Cox
Are you a Patton Computer and Internet Expert? Answer questions, earn points and help others
