0182,0190,0112. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
I found 3 codes: 1030, 1035 and 1191. Code
1030
for
Orion
TV
Code
1035
for
Orion
TV
Code
1191
for
Orion
TV
For other devices, try the remote code finder http://remotefinder.rca.com/default.aspx?site=rca . Try the search twice if it gives you a problem the first time. At times, the search engine has server issues. Please note that if the remote was programmed less than 6 months after the TV was released or is older than the TV, the code you need may not be part of the programming. In that case, you need a newer remote or one that is programmable (via a computer's USB port for example).
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Orion has made Emerson,Sansui, Admiral, Memorex, RCA, Toshiba, Insignia, Akai and Zenith.
Try those codes. You can call Orion at 800 289 0980. I think the replacement remote for the FTDV2004B is less than $20.
need the code for orio tv with rca remote
