Hi, from experience i recommend you use a semi fluid type grease
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82915557&contentId=7022530
From inspections , it's works best..... Oil will leak....
Regards
SOURCE: looking for manuals for mercury m48 scooter
Try here :-
http://www.drivemedical.co.uk/technical/z40974.pdf
cheers, Pete
SOURCE: my charger for my scooter says abnormal red light flashing
Please check the charging voltage and if this is abnormal the charging circuit is faulty, check the connectors and the links before we can suspect the main unit.If not the battery and terminals needs to be checked as the possible suspect.
