i assume that you are accessing the web page by typing
http://192.168.0.1 on the address bar of your internet browser(default username is "admin" and leave the password blank ". if so,
-check if the computer's ip address is on the same segment as of the router's ip address (go to command prompt and type ipconfig or right click on your local area network and click on properties to check the ip)
-if the the computer is getting a valid ip address, try to ping the router's ip address and check if it'll provide you replies. if so, try to disable any firewall or any antivirus enabled on the computer
-if the computer is not getting a valid ip address, make sure that the computer is set to dhcp instead of static ip. check if there's a light on the port where you connected your computer. if there's no light on the router, use another port or use another known working ethernet cable
-if this router is just for inital setup, try to reset it and try again
-you can also try to use another computer or another web browser to isolate the problem
hope this'll help you.
ciao!
