I'm going to quote dsteele04 on this one (he is a user of this site).
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as
16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m.
would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed,
access panel is on the back. It uses a watch type battery.
~DLS
On page 16 it explains two ways to set date & Time.
1st is when you turn on the power it will ask you to set the time & date, and you can enter it.
2nd way to set time & date, or change it is to press the MENU key, and select "Set Date & Time".
I hope this helps you.
Please also giving me a good rating for offering you help, :-)
Thanks,
The date/time is in Setup 1 (the wrench icon in the middle). Scroll down to Date & Time, then click the right side of the wheel button to set the date and time.
I hope this helps! If so, please rate the solution. Regards, Char1ieJ
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
the time and date setup should be in the settings menu. open the menu then go to 'settings'. scroll down to 'initial setup' and select this option, then you select time and date. this is where you set up the time and date. :) hope this helps.
