Dishwashers Logo
Posted on Sep 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KitchenAid Dishwasher fill up with water after use
We have a KitchenAid dishwaser Model # KUDI02CRWH0 it filled up with water and flooded the floor when we were away on holidays. We ran a cycle through it and it seems to work but by morning it has water in it and is leaking again. What do I need to look at or fix to get this unit fixed with out calling in a repair man?
  • 8 more comments
  • Anonymous Nov 03, 2007
    I turned on my dishwasher and ran it, it worked fine but now it is getting clean water in the bottom of the dishwasher and it has ran on to my floor.
  • Rick Nov 20, 2007
    I have a different KitchenAid built in dishwasher Mod # KUDP02CR, but had a similar problem. Went on vacation, came home to find water in dishwasher and buckled wood floor. Water in house was turned off at intake to house and the drain has an air gap. Only water available was in the pipes which probably localized the floor damage. I hate to think how much water would have leaked had the water been on. It hasn't happened again in the past week and have used 2 times and do not seen any water leaking into the unit. What could have caused this leak? The unit is just over a year old.
  • Anonymous Mar 22, 2008
  • Anonymous Jun 04, 2008
    after running dishwasher dish it appears to refill with dirty water have tested it and itfills from water used at kitchen sink i think it is a problem with the hose but do not know what to do to correct it
    [email protected]
  • BVaa Jan 20, 2009
    I have Model KUDS03FTPA03 and the water is clean and not draining -- flooded on to floor.
  • Anonymous Mar 14, 2009
    kitchen aid dishwasher feels as if the door spring broke. can i fix this?
  • posenday May 11, 2010
    Great suggestions! I like the loop. I'll get back with the results.
  • Anonymous May 06, 2013
    did you get this resolved? i am having the same problem with my dishwasher:(
  • Anonymous Mar 16, 2014
    Water will not flow into newly installed KitchenAid KUDE48FX
  • Anonymous Mar 23, 2014
    I replaced the float switch and it worked fine for a few weeks, now during the fill cycle it's leaking again.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Sep 22, 2007
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735463
Points
22413
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
  • 3 more comments
  • Anonymous Sep 23, 2007
    It would be both considerate and helpful if you would post back comments. If you rate advice as "Not Helpful" and don't leave any remarks, how can the technician help you any further? The advice I gave you is a best guess solution based on the symptoms you provided. It's often very difficult to provide an exact solution when I'm not there to actually see what is going on with your appliance. I base my advice on my experience as an appliance repairman and have corrected this problem on several occasions. I took the time to give you detailed advice on what to look for from the simplest possibilities, first. That way you rule out the possibility of overlooking something simple and purchasing parts or spending money on repairs that are not necessary. What have you done to determine a solution? Has your problem been resolved? Do you need further guidance? Good luck to you.
  • Anonymous Dec 12, 2010
    Thanks for the help! With your assistance, I've diagnosed the problem as a faulty fill valve. Now, I just need to figure out how to fix it! For the time being, we are shutting off the water to the dishwasher from under the sink, until we figure out how to fix it.
  • AMommy Dec 31, 2010
    PERFECT, I almost have this figured out for my crappy Kenmore dishwasher. I see clean water coming in through my fill port just like you said. The water keeps flowing at a pretty good amount consistently. It does completely STOP when I shut the hot water valve off under the sink that goes to the dishwasher. So, now is this a dishwasher problem or..do I need a plumber and have a leaky water valve under my sink that needs replaced?
    Thanks for your help, its been a long day of wet floors around here.
  • Tim Wit
    Tim Wit Feb 11, 2019
    Thank you Jeff for the explanation.
    We had water all over our kitchen floor and I wasn't sure where to start.
    After cleaning up the water on the floor, I used a cup to take most the water out of the dishwasher tub, noted the water level, then came back a couple hours later and found the water level had risen since the last time I was there, so now I know to order a new fill valve.
    Thank again!
  • Keith Renfro
    Keith Renfro May 17, 2019
    If you shut the valve under your sink and it didn't stop yes that is a plumbing issue and the valve needs to be replaced.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 21, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11511
Points
5
I have been reading and seen what other people has posted. I have a bad valve, it is leaking on the left side just like you said! Now how do I get this off? Twist it, turn it, or lift it? I don't wanna brake it!!! This is also a KitchenAid!? Model KUDRO1TJ... I have a few problems with this washer over the years! Is it just this brand dishwasher? Please help! And where can I get this valve at?
Thanks ahead
  • Anonymous Jan 28, 2008
    It worked!!! It was the water valve everything is all well now, no more floods!!! I'm a happy camper :-) Just wanted to say Thanks! I will be back for help here on fixya. Great Site!! A++++
    Thanks
    -Want Help
Anonymous
Level 1:
  • Posted on Apr 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11511
Points
It could be a stuck overflow protection float, a bad spray arm seal or door seal seal or food / foreign objects in the way of the door.
Home questions may be directed to Dana Casey of Minnesota tchouse.net
COSTEL TURCU
Level 1:
  • Contributor 4 Answers
  • Posted on May 18, 2019
COSTEL TURCU
Contributor
Level 1:
Answers
Questions
0
Helped
11787
Points
15
LA INTARE AP? IN MA?IN?,ESTE UN VENTIL ELECTRIC
(robinet ) CARE NU MAI ?NCHIDE BINE ! SE DEMONTEAZ?,
SE CUR??? DEPUNEREA DE MIZERIE DIN AP? ?I CU FIRELE ELECTRICE SCOASE, NU TREBUIE S? CURG? !
DAC? NU SA REZOLVAT,SE SCHIMB? ELECTROVENTILUL CU UNUL NOU !
Anonymous
Level 1:
  • Posted on Dec 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
11511
Points
I have a kitchen aid model kudio1flss2 and the upper arm is not spinning and now I am getting 2 flashing sequence from the start button????
  • Keith Renfro
    Cut the power to it off at the breaker and leave it off over night. This should cancel the code that is causing he flashing sequence and return unit to normal if there are no mechanical issues. If it doesn't the main ECU or control module needs to be replaced.
Kitchenaid kuddo1dppa
test this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 22, 2013 • Dishwashers
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 • Dishwashers
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
My d 3122 keeps filling, overflows and pumps out,... it trpis the flooded switch. Ive tested the filling solenoid and it works ok. I suspect the pressure switch....where is it and what does it look...
The float switch is located on the inside of the dishwaser. Under the bottom rack and it moves up and down make sure it goes up and down freely that should tell the water to stop pumping in when the float rises
1helpful
2answers
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
1helpful
Broken dishwasher?
The dishwaser has a Anti-Flood device (a polystireene block) on the floor of the dishwaser that activates a micro switch if any small amount of water is on the floor of the washer for any reason. This switch automatically puts the washer on PUMP OUT mode and does flash the error mode and does not work. Find out what causes the water on the floor and that will be the reason for not working...
Hi my bosh dishwaser wont fill with water
check dicharge hose needs to be 3/4 high on dishwasher about 18 in above floor
3helpful
2answers
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
3helpful
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
