Televison & Video Logo
Posted on Oct 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a pn64e550 plazma that has no picture, if you turn it on and off several times it might come on for about 3 min. the go out ,the sound works fine...
matt martin
Level 3:
  • Samsung Master 1,259 Answers
  • Posted on Oct 05, 2013
matt martin
Samsung Master
Level 3:
Answers
1259
Questions
12
Helped
297131
Points
3635
Plasma TVs are difficult to repair. I have not repaired the particular model you ask about. I would certainly pull the power supply board and inspect it for a bad solder ground. Many times this will repair the TV. Be sure to also take a leaf blower to the open back of the TV as well. Dust will act as an insulator, and create extra heat that will break your solder grounds. If worst is to meet worse, you may have a bad Y suspension board. The Y suspension board will take some effort to remove, and if this board is bad, send it in for repair. But let me remind you, the first note of this info is the best effort to fix at any level, and is usually the problem. Also, there may be one bad capacitor on the power supply as well, replace with same value. If you cannot repair this TV yourself, take this info to a TV Tech.Thanks for asking me!
5 Related Answers
Anonymous
  • 632 Answers
  • Posted on Sep 26, 2009
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Chi Chu
  • 8457 Answers
  • Posted on Sep 29, 2009
SOURCE: I have 42 inch plazma no picture
Ur backlight video inverter board is dead.Buy parts like capacitors for replacement with soldering or buy the whole board.Tries these websites.Shopjimmy.com,Partstore.com or Ebay.com.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 28, 2009
SOURCE: Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "Plug and outlet are ok, well drop it off at best buy to fix. Thank you."
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Dec 15, 2010
SOURCE: 52 inch plazma tv LG keeps turning off and each
hi,
i think ur tvs colling fan has some problem. open the back cover of ur tv and then power it on. watch is the cooling fan is working or not. normally it will be in top the left and right side. if it is not working. remove the power. then remove the fans clean it with a brush. u can see a label on the fan in which its specification are written. remove the label. and put two drops of oil in its bearing. turn the fan leafs with ur finger for some time till it runs freely. fix it back . then power on ur tv .
ok
Anonymous
  • Posted on May 03, 2011
SOURCE: tv turn on no pic or sound
I bought a tv form china, which model is LG 42sal80yd-ca. i was update firmware dtv v3.15 epk.then its restart and it does not on, only power light on and black screen the it off automatically, not its on and off continue. please help me
Sony xbr-49x900f tv has sound but no picture after a min or shorter
Hello
in this case ld board is defective please replace ld board .
thanks
M Nasir
My 42 samsung plasma tv lost picture
hello i have a 42inch plazma pdp42v6 check all caps ok
all board ok sound ok but no picture can anyone help me
fix this problem please
2helpful
My plasma has sound but not picture can you help me??
Not with this little information, but there are several reasons too look at. Plazma tvs use several boards to creat a picture, these are the x and y sustainers and a buffer board. There is also a main power supply that creates a lot of heat and these tend to go bad also. The set could have some how lost the gas charge in the display but thats unusuall. Most likely the sustainer boards need replaced and these aren't expensive but I don't want you to just throw money at it. Get someone to diagnose the set before you replace any boards. I wouls also caution you to not spend too much because you can get real nice LED tvs for a fraction of the cost of the plazma and plazma is on the way out.
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
4helpful
  2. Turn on the TV.
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
30-45 min into use the picture goes black
Sounds like something may be broken try calling the place where you bought and if the warrenty is still in effect you can get a replacement
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Plazma burn in from video games
Plasma burn-in occurs when the same picture is on the screen for a long time. You should only have a problem if you leave the WII on a menu for extended periods, or leave it paused for extended periods. Be careful about that, and you should be fine.
-John
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
