Lands Phones Logo
stefan ber Posted on Oct 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change the number of rings on my cordles telephone TRU9260 series
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Lands Phones Master 102,366 Answers
  • Posted on Oct 05, 2013
Lands Phones Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441119
Points
622693
The ring count is controlled by the answering machine or voicemail system on your phone line. The TRU9260 is just a phone, it will ring until your or the answering machine/voicemail system picks up.
What answering machine/voicemail system do you have?
Testimonial: "Thanks, I will call AT&T to change my number of rings."
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
1helpful
How do I turn offn the mute on my handset?
Press the CLEAR button just above the 1 on the number pad.
If you need a manual you may download a copy here.
1helpful
Hi, I have a Cordles phone Uniden 6.0 Model: DECT1588-ST. Problem: The call gets automatically attended, after 6 rings at the max. Since the Number of Rings can be set to a maximum of only 6...
Hi
owners manual page 46 how to turn answer on/off
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/DECT1588om.pdf
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
2helpful
2answers
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
1helpful
2answers
Everytime the phone rings my wireless connection goes away. I am also unable to secure this network. the model number is f5d8235 4
Your phone is using the same frequency as the wireless router (2.4GHz). It would be very difficult to prevent this unless you change:
1. Phone to corded system.
2. Change phone to cordless DECT (5.8GHz) system
3. Change network router from "G" series to "N" series.
Shared telephone ling malfunctions sometimes
It looks like you have a distinctive ring service from your phone company. Change the ring pattern of your fax to its assigned ring pattern (double or triple ring). It could be assigned to 'all rings' right now, that's why your fax is picking up your landline calls as well.
I have a fax number shared with my telephone line. It malfunctions when recieving a telephone call - only sometimes and on only two numbers. When someone tries to make a telephone call to me from those...
2answers
How to get the telephone to ring only a few times.
on the 2080 series it is:
press MENU/SELECT button
scroll to ANSW.SETUP
scroll to RING TIME
press MENU/SELECT
scroll to # of rings you want
press MENU/SELECT
remote pin is under ANSW.SETUP --> SECURITY CODE
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
