With the wheel on you will have a 3 pronged washer, make sure that the screw on the stop motion wheel is unscrewed all the way, put the stop motion wheel back on ans tighten it hand tight only, tighten the screw in the stop motion and see if the stop motion frees off and then tightens again so the machine will work, if it does not take the stop motion wheel of again and move the 3 pronged washer in a different position and put the stop motion wheel back on again
SOURCE: adjust hand wheel bernina 1008 sewing mmaachine
Barbara. When you removed the handwheel did you find a bit weird looking washer with ears around the outside and to fingers pointing to the center of the washer? If so you probably put that in backwards. The center fingers are slightly bent... they would be bent toward the outside.
