First it kept saying theirs a issue with the cooling system and it would keep shutting down, then I read online it was a glitch thru Toshiba and uninstall the value added package so I did and now it just keeps shutting down
Does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
SOURCE: toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
SOURCE: I have a Toshiba Satellite L355-S7811 laptop that
See let me talk with you from experience...
The only thing that can be done is system restore to factory default and remember to backup your documents.
This is the only way to resolve the problem you are going through.
Cheers.
SOURCE: Toshiba satellite 5105-s607 insert system disk
Log into the bios and change the boot order to boot from the CD - it will then boot up your CD system Disk first
As the PC boots - you should see a message to get into bios/setup
usually F10, F2 or del key varies buy manufacturer
then look for the bios section for boot order and make sure the CD/DVD drive is set to before the harddrive
SOURCE: Toshiba Satellite A105 laptop keeps shutting off for no reason.
System Restore tool provided on Toshiba Satellite A105 laptop can help you to restore the system to an earlier date. The sudden shut down problem may occur if some important system files are missing. System Restore makes use of the backup copies of important files in the restore point to replace faulty ones that are causing the sudden shut down problem. Restoring the system to an earlier trouble free time will help get rid of the sudden shut down issue in Toshiba Satellite A105 laptop.
