SOURCE: how much will be height from one point to other for 14.4 mts with
I am not exactly sure what the 14.4 m distance represents: The horizontal part or the inclined one.
A. If the 14.4m is the length of the horizontal leg, then the height is given by tan(3 deg)=h/14.4m or h=14.4m*tan(3 deg) =0.75467 m.
B. However if 14.4 m is the length of the inclined part (the hypotenuse) of the triangle, then the height is given by
sin(3 deg)= h/14.4m or h=14.4 m *sin(3 deg)= 0.75363 m
As you can see, the values are approximately equal, because for angles less than 10 deg, the sine and tangent are approximately equal.
I am no construction engineer, but it seems to me that a 3 deg pitch in not much of an inclination. Maybe you meant 30 degree pitch.
If that be the case, the calculations are performed the same way as above: Just substitute 30 deg for 3 deg.
SOURCE: I need to be able
To access the DMS symbols
Here are two screen captures to show you the contents of screen
SOURCE: a tree on a hillside casts a shadow 215 ft. down
x is the height of tree, y and z are as denoted in picture:
Please rate my answer if it was helpful :)
