SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: what is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal
2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever
made. You may also use this oil in any other brand of 2-cycle air
cooled equipment, but it should always be mixed at the 50:1 ratio
whether or not it was a 32:1 or 16:1 etc. machine. This oil is the
highest quality 2-cycle oil on the market today. There is no need to
have more than 1 tank of fuel for your 2-cycle equipment any more.
Do not forget to rate the answer, Thank-you
