The shower is coming up with low pressure soon as you turn on checked filters all ok
Remove the shower head and check the water flow. If it is good, look inside the head for a restrictor that is designed to reduce the flow rte. It can be either rubber or plastic, with a smaller hole than the inside diameter of the pipe. Remove the restrictor and re-install, making sure that you still have a rubber washer to prevent leakage.
Best regards, --W/D--
