SOURCE: my magnet cracked on my jbl sub woofer can it be
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
SOURCE: My jbl venue series subwoofer 10 keeps making a popping noise
sounds like the capacitors need to be replaced make sure you replace them with the same value mF
SOURCE: My JBL Venue Sub 10 light stays red, will not
i have the same problem. don't as yet have a solution
SOURCE: the fuse keeps burning out in my jbl sub 10, even
poor design, the amps that are screwed to the heat sink are below a transistor which is catching all the heat,heat rises and changes the bias of the transistor so high it causes runway in circuits that results into failure also the amplifiers are sealed with no air flow, this can't be good.Maybe if they put air vents or remove the cover to panel then the heat will have somewhere to go instead of just building up inside.If this problem is not fixed a replacement is going to fail too.good price bad design.
SOURCE: Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
