Hi
We were having problems with a noise when our washing machine was spinning, ( thought it might a bearing or belt problem ). Took the back off the machine and turned the machine on to check, machine started letting in the water, then stopped and wouldn't go any further. Changed wash cycle to spin mode, then a flash came from the back the machine near the drum and won't go at all now. Any help would be welcome. Machine is a Bosch 1200 classixx express (WAE 2416). Thanks Alan.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Thanks for replying to my problem, jnr. Can you tell me if i would still get power to the machine, if it was the brushes, as at the moment the LED display is not lit and it appears that there is no power at all. I have checked the plug fuse. Thanks Alan.
i have the similar prob. While washing, the machine stops and then no power at all. Tried changing the fuse but still no power. The LED screen seems died.
