You pushed the wrong button! On the left side of the LCD display, there are four buttons. One is labeled "ISO" and the other "QUAL". In the viewing mode, these buttons are used to allow you to scan multiple frames at one time. Each time you press the ISO button, it increases the number of images displayed. Each time you press the QUAL button it reduces the number of images displayed.
SOURCE: can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
SOURCE: Nikon D40 Monitor blank when shooting picture. Viewfinder OK
while using slr cameras u always see in the viewfinder bcuz slr is a single lence refleime u can see the picture after shoot by clicking on play back option this is a feature of an slr camera
SOURCE: My Nikon d90 monitor does not display when I turn it on.
By default the D90 is set to use the viewfinder for framing and taking pictures. If you wish to disable that and use the monitor, press the "LV" button on the back just above the multiselector.
SOURCE: i accidentally protected a picture
There are 2 ways to do it. Firstly you can format the card - this will delete all images, including protected ones. Second method is to display the image in full frame view mode (or highlight it in thumbnail view) and then press the AE-L /AF-L button. This will remove the protection - or protect an unprotected image.
Hope that helps
