My laptop is a vostro 3500 windows 7!
First of all note that by doing this your warranty will be void.
1. Take out the battery
2. Remove the bottom panel
3. Remove the screws under the bottom panel
4. Slide out the DVD drive where there are another 2 screws
5. Carefully remove the keyboard
6. Remove the thin ribbon cables for the keyboard, trackpad, etc
7. Remove the screws under the keyboard
8. Gently pry apart the top and bottom
9. Remove the heat sink fan
10. Remove the monitor cable
11. Remove any screws holding the larger motherboard
12. Remove the larger motherboard
13. Replace the hard drive
SOURCE: problem after installing windows 7 on my vostro 1500.
Go to the control panel > Power Options > go through the settings and make sure that hibernation and sleeps setting are turned off. Most BSOD are caused by memory problems and most memory problems come from the computer trying to wake up or come out of hibernation. It is a useless setting and would be better if the computer just ran.
SOURCE: webcam driver needed for dell
Go to the site below. Double check the model and then fill in your operating system type and other info. This will take you to the page that has all the drivers for your laptop. You should find the webcam driver there.
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=VOS_N_3500&os=W732&osl=en&catid=&impid=
Make sure the link includes the = (sign) at the end of the line that didn't copy correctly here.
SOURCE: my dell vostro 3300 laptop battery not charging since i re installed windows 7
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
