Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Oct 03, 2013
Printing borderless with the C652 - Konica Minolta bizhub C250 All-In-One Laser Printer
1helpful
When using canon pro 9000 with photoshop on a MAC Snow Leopard computer, I cannot print borderless pictures. How can I fix this problem
Preserve your memories forever with borderless printed photographs--while saving money and time by printing from the comfort of your own home. Some printers do not have the option of printing borderless prints, so make sure your printer supports borderless printing before beginning this project.
  • Download your digital photo to your computer from a digital cameramag-glass_10x10.gif, email or the Internet. Save the photo to your hard drive to a folder that you can find later such as "Pictures."
  • Step 2Open your digital photo in a photo-viewing software. Click "Print" from your menu. Go to your printer properties to change your printer's "Page Setup." Access "Properties" through the "Preferences" or "Options" link in your "Print" dialog box. Many software programs have a default margin or border for photos; to print borderless photos, you'll have to remove the default margin.
  • 1helpful
    Epson R2400 letterhalf borderless printing
    No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
    Borderless printing with a dell 3010cn
    This is application driven and you will need to set this up from your application or when you File / Print select the Print Preferences for the Dell 3010cn and then select borderless printing
    1helpful
    How to do borderless printing with an oki c5300
    You cannot do borderless printing with a toner/fuser based unit.
    The printer needs a paper grip area and cannot print to the edge due to the fuser.
    How do I print borderless pictures on my Selphy DS810?
    You print borderless by choosing that option in the print software, after choosing print, you go into printing preferences and choose borderless..
    Settings for printing a borderless 8x10 on a canon i9900
    Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
    Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
    HP C6180 won't print borderless photos
    Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
    8helpful
    2answers
    MP600 with Mac OS X - no borderless printing option?
    I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
    1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
    It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
    FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
    Borderless printing kodak 5500, clear coating business cards
    The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
    1. Click File , then Page Setup .
    2. In the Page Setup dialog box, click the Paper tab.
    3. Under Paper Size, select the appropriate borderless paper size.
    To select borderless printing in the printer driver, follow the steps below.
    1. In the application, click File , and then click Print .
    2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
    3. Select the appropriate borderless paper size.
    HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    ZJ Limited
    ZJ Limited
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
