Question about Samsung Galaxy Cell Phones
My calls say restricted on their end. - Galaxy Samsung Cell Phones
  • 416 Answers
Ifn you can take call from tyour phone then you have mno isue on your device. The reciver will have to check there unit or a network barring facility
Posted on Oct 04, 2013
SOURCE:
How can i see restricted calls made from my phone
  • Look at your phone records at the end of the month. Some cell phone and home phone providers list numbers that are restricted on the phone bill. Simply note the date and time the restricted call came into your phone and look for that date and time on the print out of phone calls made and received on the bill. The actual phone number may be there.
    Have a block put on your phone that notifies callers that you do not accept phone calls from restricted numbers. This will force the individual calling you from a restricted number to unblock his phone number and call you again, if he wants to contact you badly enough.
  • Install a toll-free number to use on your phone. When you have a toll-free number (with most providers) and only give out that number instead of your traditional phone number, you automatically receive the numbers of everyone who calls because you're paying for the calls that come to your phone.
    Jan 04, 2015 | Cell Phones
    How can i view restricted calls made from my verizon phone
    Look at your phone records at the end of the month. Some cell phone and home phone providers list numbers that are restricted on the phone bill. Simply note the date and time the restricted call came into your phone and look for that date and time on the print out of phone calls made and received on the bill. The actual phone number may be there. Install a toll-free number to use on your phone. When you have a toll-free number (with most providers) and only give out that number instead of your traditional phone number, you automatically receive the numbers of everyone who calls because you're paying for the calls that come to your phone.
    Why do none of your so called experts know how to de restrict an a.j.s.125 dde, or even answer if it can be done
    different bikes restrict by different means, sometimes smaller carbs are put on other times the jets are just changed to a lower width, the exhaust shape can restrict airflow from the engine. sometimes the airbox restricts flow into the engine. so first stop is check how high a jet you can get for carb, maybe get a jet air filter racing kit.may need to change exhaust for a power pipe. you can put a bigger sprocket on front end for less accelleration but higher top end or smaller for higher accelleration. you can put a bigger sprocket on back for greater accelleration loosing top end. you could change the piston for a higher compression piston and/ or have the head skimmed. the list goes on and if its a 2stroke there's reed valve to play with.
    Mar 18, 2013 | Motorcycles
    Type your problem for a solution...HOW DO I FIND OUT WHO CALLING MY PHONE RESTRICTED? I DONT HAVE HER NUMBER.....HER NAME IS VICTORIA BROWN 25, TEXARKANA,AR 71854
    You can check your phone records at the end of the month, sometimes providers will "unmask" restricted numbers when they put them on there. You'll have to note the date and time of a call though. Another way to do it is to call up your cellphone provider and ask them how to go about blocking restricted calling. Usually it's a setting on the phone itself, but every phone is different. You can then change your voicemail to say something about you're now blocking restricted numbers, so if they want to get in touch either leave their number in a voicemail so that you can call them, or unblock their number.
    If you're getting harassed by someone with a restricted number, you'll obviously want to call the police. They can get all this information almost instantly.
    If you're trying to find the number for Victoria Brown, and it's not listed, you might not have any luck. However, I've had some decent luck on a site named spokeo. I took the liberty of looking her up on there, there are several different Victoria Browns who live in Texarkana, AR so you might have to check several of them until you find the proper one. The results of my search can be found by clicking on this link. Hope this answers your question, if not let me know!
    Sep 15, 2011 | Cell Phones
    When i call someone on their end it comes up restricted
    What is Mobile Phone Model?Which Country it locked now?
    Try restriction code at
    http://www.prounlocking.com/samsung/rs8wp8/ and Unlock it.
    Mar 17, 2011 | Samsung Cell Phones
    My problem is that my phone call ends after 1 hour and 30 minutes of talking everyday what's wrong with my phone
    there is nothing wrong with your phone...there is a network restriction for all the customers that ends the call after one hour and 30.
    Oct 06, 2010 | Cell Phones
    Hi, i have purchased a nokia E71 on Ebay which was described as unlocked.After recieving phone i put in a Vodaphone prepaid sim only to find call barring was activated.I then contacted seller to find he...
    Hi
    the default is 0000 or 1919 or 1234
    Call barring
    Call barring (network service) allows you to restrict the calls that you make and receive with your phone. To change the settings, you need the barring password from your service provider.
    1. Select Menu > Tools > Settings > Call barring.
    2. Scroll to the desired barring option, and to request the network to set call restriction on, select Options > Activate. To set the selected call restriction off, select Cancel. To check whether the calls are barred, select Check status. To change the barring password, select Edit barrings passw.. To cancel all active call barrings, select Cancel all barrings.
    So try contacting your Vodaphone customer service and ask for the call barring code, see if it opens up with a code that they give.
    Aug 30, 2009 | Cell Phones
    Pls send me the restriction code of my phone nokia xpressmusic
    Nokia
    To By Pass SIM Lock:
    Turn phone on then dial 112 call # send end send end. This work until the phone is turned off.
    Warranty Code: [*#war0anty#] *#92702689#
    View IMEI *#06#
    Default security code: 12345
    Aug 24, 2009 | Nokia 5320 XpressMusic Cellular Phone
    How can i stop my incoming calls
    Enter Menu 4-3-1 (Settings-Security settings-Restrict calls).
    The "RESTRICT CALLS" options will be displayed.
    Use the arrow keys to select "RESTRICT OUTGOING CALLS" or "RESTRICT INCOMING CALLS" and press the softkey under "SELECT."
    A display prompting you to enter your Security Code will appear.
    Use the keypad to enter the Security Code and press the softkey under "OK."
    The choices "SELECT" and "ADD RESTRICTION" appear on the display.
    Select "ADD RESTRICTION" using the arrow keys and press the softkey under "OK."
    A display prompting you to enter the number string you wish to restrict will appear.
    Enter the number string or name you want to restrict and press the softkey under "OK."
    Example: 1905 will restrict all calls beginning with 1905.
    262 will restrict all calls by the name of Bob. B(2)o(6)b(2).
    The message "Saved" appears and he desired numbers will be restricted.
    Dec 28, 2008 | Nokia 1600 Cellular Phone
    Cell Phones Logo
    27 people viewed this question
    Top Samsung Cell Phones Experts
    Felizardo Erilla
    Felizardo Erilla
    Bill Long
    Donni Steen
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
