Computers & Internet Logo
James Posted on Oct 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Go kart will not start, when you turn the ignition on it just clicks. THe starter and starter relay solenoid have been replaced. The wire coming from the solenoid to start is extremely hot after trying o start.
Denny Giesel
Level 3:
Master:
  • Master 818 Answers
  • Posted on Oct 04, 2013
Denny Giesel
Master
Level 3:
Master:
Answers
818
Questions
0
Helped
152704
Points
2428
It sounds like you have electric start like a lawn mower. There are 2 possible reasons for the cable to be getting hot-1 there is a dead short in your starter motor- check this with a volt ohm meter. set to ohm disconnect the fat positive wire on the starter and touch the terminal and then ground-should read 1-no continiuty-no short or if shorted will read 0.00. #2 motor is stuck and starter motor can't move it. If you can turn the motor over by hand to see if its stuck. I suspect your starter motor is bad. Hope this helps-Denny
2answers
1992 honda accord wont start when clutch is depressed
Can you push it off and pop the clutch in 2nd gear to start.
ITurn key, clicking sound, no turn over
If it won't crank over, it's a problem in the starting circuit, not the ignition circuit. Check your battery and starter for clean, tight connections. Listen for that click to see if it comes from the starter solenoid on the starter-maybe have someone try to start it while you watch and listen under the hood. If the click is from the solenoid (and not from the starter relay), then the starter is not getting full battery power to crank (bad connection), or the starter needs to come off and be tested.
If the click is from the starter relay, you could pull off the little purple wire to the starter solenoid and see if it has 12 volts when the key is in start position. If you have power there in cranking position on the switch, the solenoid is bad or the starter may be the problem-again, it will have to come off for testing. If you have no power at the solenoid in cranking position, the circuit from the ignition switch to the solenoid is not working. The start relay and the neutral safety switch (or clutch switch if manual transmission) are in the starting circuit from ignition switch to the starter solenoid. Good luck.
1helpful
Switch is on, turn key, no signal to starter, no click no contack
COMMON CAUSES OF NO-CRANK NO-START
Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
I have a 2003 Saturan Ion that won't start
Hi, this is what you should do when your car won't start. Diagnosing a no-start condition requires a logical approach to figuring out what might be preventing your car from starting. First, if the engine won't even crank over when you turn the ignition to START, your car obviously won't start.
When you turn the ignition key to start your car, voltage from the battery flows through the ignition switch to the Park/Neutral safety switch and/or brake pedal or clutch pedal safety switch (you have to push the pedal down before the circuit will complete) to the starter relay or solenoid. When the relay or solenoid is energized by voltage from the ignition switch circuit, it closes a contact that routes more power from the battery directly to the starter to crank the engine. The starter motor spins, pushes the starter drive gear to engage the flywheel and cranks the engine.
If the engine fails to crank, there is a fault in one of the components in the battery/ignition/starter circuit. Check it out.....
  • Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
  • Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
  • Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
  • Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
  • Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
  • Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
  • Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
  • Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
  • Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
  • Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
I have a 1997 grand prix. Most days it starts. once in a while it will not start. You can sometimes rock key back and forth quickly and it will catch. But most of the time odly enough wait over night and...
4helpful
My car does not start or turn over. The radio works and so does the fan.
2helpful
2answers
Engine will not turn over. lights, horn, everything else works, no clicks, no nothing, but it will not turn over.
You're describing a no rotation issue and not a no start issue correct? If you dont hear/feel the starter relay clicking, it eliminates everything in the circuit to that point meaning the ignition switch, Transmission Range Sensor (TRS) (you don't have a neutral start switch unless you have a rare manual transmission), ground input from the Powertrain Control Module (PCM) to the starter relay coil, and starter relay are good. Based on what you've said that leaves the primary battery cable from the battery to the starter, and the wire from the starter relay to the starter solenoid contact on the starter. Have you checked their continuity? One more voltage to check at contact 30 (input volts from battery to starter relay contacts) on the starter relay socket. Should see 12vdc all the time.
You should check the battery. The true test is a load test. Does jumping the battery using jumper cables make any difference? If it starts, change the battery. I take it to check the starter you jumpered the solenoid contact on the starter to the battery correct? Have you tried wiggling the battery cables as you turn the key? They can corrode and fail internally. Are the engine and chassy ground connections clean and tight?
What can it be
I have both a Stealth, and a 3000GT, so I guess you could say that know a bit about the platform. this sounds like one of three possible things.
  • Starter
  • Starter relay (in that funny shaped box behind the passenger side headlight)
  • "click click start" or maybe loose trigger wire at the starter
If you know anyone with a 3000, try to borrow their starter relay, it is about a 10 second swap, and you will know very quickly if it is the problem.
If the starter solenoid isn't even clicking, I am leaning heavily towards either a completely disconnected trigger wire, or a bad starter. If it is clicking, then it is most likely click click start
click click start occurs because Mitsu, in their infinite wisdom put a wire to the starter (the trigger wire) which was BARELY sized large enough to carry enough current to activate the solenoid on the starter, over time, and corrosion, the wire becomes too thin to carry enough current, so it does not fully engage the solenoid... the solution is to install a relay at the starter so the trigger wire closes the circuit in the relay from the hot power side of the relay to the trigger. The hot power side of the relay is ALWAYS on, and the wire is big enough to carry enough amperage. Thats the way I did it, you can also put the relay up by the battery, here are instructions for doing it this way, personally, I like the relay down tie-wrapped to the starter myself.
Grand Canyon Tech
Grand Canyon Tech
