SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
SOURCE: The machine makes a very loud noise when grinding
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
SOURCE: My Coffee from my DeLonghi
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
SOURCE: Lost the instructions / booklet
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
SOURCE: Defuser unit stuck at bottom
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Please dont forget to vote this answer was helpful
Many thanks
