OK, on day when i turned on my iriver, it says "system files missing, to restore the system files, connect H10 to iriver plus." so i connect it to iriver plus and the iriver says "USB connected" but iriver plus doesnt recognise t, like it is not connected, i have tried what other soloutions were given, but the iriver doesn't appear on my computer, but it does on safetly remove hardware, i have downloaded the newest version of iriver plus and it still doean't work. i cant get it to do anything now, not even turn off with =out takinging the battery out.
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
The simple fix for this problem is to take your iriver and smash it with a hammer. Obviously iriver has no idea how to fix this and are scamming a sht load of people out of money. So, just smash it with a hammer and mail the pieces back to iriver and ask, Can you fix that? I already mailed mine and have yet to hear back. Maybe if they get enough of these crappy smashed irivers back they will dedicate a little more time to fixing them before we go and smash them with some hammers.
Good Luck,
Aftermath33
Http://iriverinc.com/support/mtpupdate/
pls follow these instructions...
I agree with Heracles83's approach (thank you, it finally worked for me!). However I would like to add something.
I own the H10 20GB model.
I tried the above approach a dozen times, but could not get the format to complete, until I noticed a little blurb from the iriver USA site concerning updating the firmware. http://iriverinc.com/support/mtpupdate/
The player must be in UMS mode in order to update the firmware and, as I finally figured out, to format the drive as well.
The above link will explain how to connect the H10 to your PC via UMS mode.
I was able to format on the first try after that, and the updater worked immediately.
I can get on my iriver because it saids system fies missing and i cant do nothing. so can u please fites my iriver. thank you shelby bourgeois
The best solution is to buy by a new player, not iriver
How can i find iriver plus?
or something that i can download iriver...
and teach me how to restore it..
[email protected]
I thnk Heracles83's soluton is because his irriver's system files is really corrupted. But it doesn't work on thoese with Irriver's hdd problem...
ctgiok
I think Heracles83's solution is only workable for those REALLY have system files missing problem, whereby those like me with hdd spoil problem, this solution is not workable.
Hey that either means that you have a bad HD in your player Sadly a common problem.Or your player was formated wrong Step 1. Go to iriver.com download the firmware updater/repair tool. Then install and run the tool using their directions {may take a few tries}. Then if still no dice. turn on the player and hold it up to your ear if you hear a LOUD click click click before the system files missing junk then you have a 90% chance of a bad Hard drive Email me at [email protected] for More help or to find out how to fix it.
Mike
My ipod same proble show on screen "system file missing connect the h10 plus".
So pls. short out this proble and give me solution.
There is no solution!!
I want to the system iriver my system is missing
Tengo Un Iriver 10, y quiero que me ayuden ya que no he podido Resetearlo y cuando lo prendo se queda con la palabra wait y no puedo escuchar mis canciones.
Donde puedo enviarlo para que me lo arreglen
Gracias.
I have the same problem.. when i turn my iriver on its saying system files missing
Download new firm and install it man it will work for sure
I turned im i river on and it says restore system missing files
SOURCE: iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
me too....help....... this iriver suck big time man... stupiddddddddd
me too been thru same shit... m so sadddddddddd
i have the exact same problem
I have the exact same problem. system file is missing, computer doesent recognise it, apart from in the safely remove hardware. firmwire doesent recognise it either
I plug H10 to my pc. It says "new hardware found", however sometimes I am able to access it as a portable device in My Computer for about 15 seconds. Then the iriver display says "Ok to disconnect". It just wont sync properly so I can manage my music.
FUCKEN IRIVER CUNTS
I turned on my Iriver and it said system file missing. I downloaded the firmware but it tells me it can't install. it tells me to hold the select button and teh start button till the emergancy connection words come on and then teh restore wills tart uautomatically. I do this, but nothing happens. Am I doing somethign wrong? Please help me. Thans
I turn my iriver on and it tells me that the system files are missing! how do i resolve this problem?
i saw in my iriver there is system files missing
recovery of system tool
my iriver says system files missing connect to iriver plus..but what is iriver plus?
I'm having the same exact problem as stated above
system file missing to restore system files connect H10 to recovery tool
damn, i dont even know what i did to it
it just said "system file missing to restore the sysytem files, connect h10 to recovery tool. (www.iriver.com.) and i went on it it doesnt do anything
i dont even know here the heck the recovery tool is ...
yes the same problem
Files missing, can not get it to turn off without taking out the battery. Paid mega bucks three years ago and worked fine until a couple of days ago. How do I fix.
Same problem. downloaded the iriver Firmware Updater Setup.exe, but it gave the error "Device is not supported ID = IRIVER H10_kor_um."
i have a problem to restore a system files in iriver h 10
iriver h10 all files missing
iriver says system files missing connect to iriver recovery tool (iriveramerica.com) the site does not even mention the h10 or a recovery tool
h10
h10 files missing can restore
Wow it seems like a **** load of people have this missing files problem, including me. They realy need to get they're **** together and stop selling **** like this.
I have the same problem. When i turn my IRiver H10 on, I get a messag saying "System files are missing, connect to a recovery tool." contact me at [email protected] or [email protected]
"System files missing". problem
gfhdf
the same as him
I want restorethe systeme files and connect h10 to recorvery tool
I want restore the systeme files and connect h10 to recorvery tool but i don't have email please
Okay, as i have found out so far, lots of people have this problem and there is no solution except to get a new hard-drive or buy a new one. but i have email iriver again with a link to this page and i will see if i get a reply. because this is just unacceptable.
Same problem, files missing, can;t do anything with it.
mine did the same... u cant do anything... i had to send mine iriver back to the manufactures and thankfully it was still under warrenty and they did it at no charge... got it back about a month later but the sad thing was that i lost all my music and the side buttons stopped working.
When I turn my H10 on there is a message saying system files missing
I have turn on my iriver H10 and I found a message saying, 'System Files Missing .......'. I am very disappointed. I will appreciate if someone can help me to find a solution for it.
i have the same problem when i open my h10 then system files missing notification appears
dfgdf
same me
I had the same problem, but was able to correct it using the advice from
Heracles83 Also, make sure your player is in UMS mode before attempting to format it.
http://iriverinc.com/support/mtpupdate/.
when turning on the iRiver H10 MP3 player (6 GB) a "System files missing" message is shown.
one day i plugged my iriver i to a computer using my USB cabled .
and after it was done i unplugged it ,and after i turned on the screen displayed this -
to restore the system fiels, connect H10 to iriver plus.
how can i fix my iriver so i can use it a gen ?
one day i plugged my iriver i to a computer using my USB cable .
Same problem here . .so i backup the files and deleted everything.. now it is just an expensive 5GB flash memory card..but i want to use the device as it should be used
same problem
firmware update doesnt help
I have the same drama...but I have had this player for over 3 years without any real problems.
I wont be buying iriver again.
i also have a completely useless iriver, it says the same thing "system files missing" and says use recovery tool at iriveramerica.com. as far as i can tell there is no recovery tool on the website, so if anyone could help i would be very appreciative.
I have not safely removed my H10 and got its system files missing. Message shown when connected to PC: Do not Disconnect. ( signaling ). Message appear when taken off from PC and switched on :System files missing, To restore the system files, connect 10 tp iriver plus
...never ever iriver...:(
Embem's "iriver H10 "System files missing
So many ignorant and iliterate peopel here.... If you were able to recover your H10 by using MTP updater that's fine, but your post doesn't belong here. Original poster as well as some others including me, can NOT connect in UMS mode... get it?? So we're all stupid not to know how to press and hold "o" and "Power" buttons at the same time?? Whoooa...
Tell me what to do when not connecting in UMS mode after 20 or so retries.
Thanks to people who offer legimate solution to real problem
M
I encountered the same problem with this ***. But how can I do now? Where can I download the iriver plus?
i had experience that problem too, but if you wouldn't mind..try to change the operating system of the iriver..change it to rockbox, it works.
hello, I have the same problem with H10 iriver as described above : system files missing
it says when i turned to restore the systym files connect h10 to recovery tool
same problem!!!!!!!! system file missing :(
is there n e one gonna help me !!!! :( dis product is really very cheap never ever gonna buy this product!!!!!! same probie :| system file missing :/
**** ipod h10
i hit it
This is ridiculous. I called Iriver and they said the only thing for me to do would be to pay them 100.00 for them to fix it. But, I am going to try the idea the was already posted, hopefully it will work.
okay,seeing as so many people have this same problem, anyone who has tried anything, whether it worked or not, if they would be able to post what they did and the result,that would be very helpful to everyone else.
thanks heaps, Embem
When i turned my MP3 iriver H10 on it said "System Files MIssing To restore the system files, connect H10 to recovery tool." and i dont know what a recovery tool is and its a new mp3 from this guy on ebay cause he owed me a new one because the one i got from him was faulty!!! AND i dont know what to do can you please help?????
I have a message: To restore the system files, connect H10 to iriver plus.
Thank you,
I would like repare this trouble
when i switch on my irive H10 it says that the system file is missing
i have the same problem if anybody knows how to fix it please help
Whenever I am turning on my MP3 Player it is displaying this message :
System FIles Missing
To restore the system files, connect H10 to recovery tool. (www.iriver.com)
For a long time, my iRiver displayed a "System Initializing" message on startup. Now, since i disconnected the battery and let it sit for a couple of months, i get "System Files Missing. To recover system files visit iRiver.com. (or something along those lines.)
When i visit iRiver.com, there is NOTHING there about H10s or "recovery" for them. All they're trying to do is sell NEW iRiver stuff.
WHY ON EARTH would i buy anything else from these people?????
My iriver says that system files are missing and need to be restored from www.iriveramerica.com, however, when I connect my iriver H10 (20gb) to my computer via usb 2.0, it's not recognized by my computer in regular mode, or UMS mode.Â
Same problem. System files missing. The only links to the recovery tool are old and will not open after you download them. I had a spare H10 that quit working awhile back. I took the hard drive out of that one and put it in the other but I get the same message. "system files missing" My computer will not recognize the H10.
when i start my iriver h10 ipod it says that systam files ar missing to restore connect to iriver h10 plus
it make this noise at the beggining...maybe i should take it to a repare guy and finifhed it
same
O.K. so I've tried the solution posted by Heracle 83 and am having the same issues as Me59 - when pressing the o and the start button at the same time, I do get the UMS mode message, but it flashes very quickly at the top of the screen, disappears and that stupid "System Files Missing" message reappears...I've tried about 10 times and NOTHING!!! I'm ready for the Hammer Fix It!! Has anyone found a solution yet? Or do we converge on iRiver demanding a new product or our money back to buy a new product, jeez!
how do i restore my iriver to opoen up again
I downloaded this update, but I can't connect my iriver in UMS. It's terrible! I reseted it milion times, but it doesn't work :C
