Nokia 7373 Cellular Phone Logo
A
Anonymous Posted on Oct 03, 2013
Turn off headset - Nokia 7373 Cellular Phone
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
How do I turn the device on
Hi tonischramm,
To turn on the device, just press the "Multi-Function Button" on the headset. To connect/pair the headset to another device, just Press and hold the "Multi-Function Button" on the headset for six seconds. The light on the headset turns blue when the headset enters pairing mode.
Hope it helps.
Thank you for using FixYa.
After i try to turn it on, I get 1 blue flash and 3 short red flashes and it wont turn on.
When you turn on your headset, the blue light indicates it's on and
the three red flashes indicates a charged headsets. If it's not
turning on after that, try resetting the headset (turn off and on).
Turn it off by pressing the call control button until the indicator
glows red (you'll hear descending tones). Once off, turn it on in the same way (you'll hear ascending tones).
Good luck from Headsets Direct!
Cannot get plantronic device to pair with my blackberry
Try turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and select the headset then try reconnecting the two again.
How does one turn on a Motorola 537w bluetooth
To power your headset on, press and hold the Multifunction for 3 seconds until LED flashes rapidly.
To turn your headset off after use, press and hold the Multifunction button for 3 seconds until the headset flashes rapidly and turns off.
Hope it helps
1helpful
I just need a pin number so i can pair my headset to my iphone
Step 1: Set the headset to be discoverable
Turn off the headset.
Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 • Cell Phones
How do i reset my Plantronics Explorer 230
powercycle both phone and headset.
turn on phone only.
turn on its bluetooth!
no turn on headset
on phone, search for headset
it should see it
now pair... type like 0000
it should pair... if not, then the headset needs a special code... see its manual for the pairing code
1helpful
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
Try to connect it to my boost mobile phone and the phone does a scan but doesnt picks up the bluetooth signal from the headset
Try this:
First, turn your bluetooth headset off. Then, start the scan to locate the headset on your phone. Just as the scan starts, turn your headset on. You may have to do it a couple of times to get it to work - but most headsets only go into pairing mode for a short few seconds just after being turned on.
1helpful
I don't know what model Motorola bluetooth headset I have but I don't know how to get it into discoverable mode to sync it to my phone.
Most Motorola headsets automatically go into pairing mode when you turn them on. If you have a light on your headset, it will be pink when you turn it on (and will begin flashing) and then change to blue. When the light is pink it is ready to pair. If you don;t have a light on your headset, it will stay in pairing mode for 10-15 seconds.
Turn your headset OFF then, (with your phone turned ON) in your phone's menu (usually) you'll go to Settings > Connectivity > Bluetooth (and select ON) Then select, Search for Bluetooth Devices and at this point you want to turn your headset ON.
It may take a couple of tries to get your phone to locate your headset but when it does it will identify the headset by the headsets model number when it locates it.
The pairing code should be four zeros. 0000.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
