Over-voltage detection. Voltage comes out from the main regulator board will either be lower or higher than normal. Check it. To get some information, http://electronicshelponline.blogspot.com/Pull up older posts.
Does it not power on at all.. logo screens, backlight, powerlight etc? If the answer is no... remove a/c adapter then battery.. hold down power button for at least a 1minute then put battery back... plugin A/C adapter then try to power on.
First place to check will be the power supply section, look for caps with bulging top, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
