SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
SOURCE: lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
SOURCE: My Johnson Escape boat w/ Minn Kota engine stopped running
I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
