Kmix hm790 How do I split the case to replace the beater gears?
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements
each have adjustable heights. to adjust the height you need to loosen
the bolt at the top with a 14mm spanner. If the bolt was loose when it
was being used then it can get too short and not leave enough clearance
between the bolt and the machine in order to push up and turn to release
the implement. If this happens take the open ended spanner, grasp the
implement and rotate the spanner clockwise (when looking up at the
machine from below. Once the nut is loose rotate the implement until
there is enough clearance to remove it normally.
