Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
  • Anonymous Mar 30, 2014
    how to undo the child lock
    New Friend:
Posted on Jan 29, 2010
  • 71 Answers
Unplug the unit, for 5 min, plug back on and try
Posted on Apr 21, 2009
SOURCE:
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few seconds
Read more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhs
please feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok
Best regards Mike
Dec 04, 2012 | Bosch SHU9915UC Dishwasher
My Bosch logixx8 machine is in child lock and i can not return it back to normal
Press and hold the start button until the child lock turns off.
Jun 03, 2011 | Washing Machines
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
I have error message nr0 on my Bosch LogiXX8 What is wrong and how to mend?
It is the child lock. Turn machine on & then press & hold the start button for 5 second. Code will flash then disappear & machine will be back to normal.
Page 5 of instruction manual for more details
Oct 18, 2010 | Washing Machines
How do i get the child lock off to operate the machine please
You have probably inadvertently activated the child lock. You can start a cycle still, but you will need to hold the start button for approx 5 secs. Check you user guide for deactivation instruction.
use link to get manual if needed
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Jul 08, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Child lock flashing
Hello Lynn, Welcome to fixya. The key symbol indicates the washer has somehow been placed in the "child lock" mode, hence it won't allow any program to over-ride it. Here's what to do to deactivate it... 1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display ) 2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display. 3) Finally by pressing the start/pause button the key symbol should disappear confirming you have successfully exited the child lock program. That is the procedure for the child lock function on your Bosch washer and should solve your problem. Let me know if this was helpful to you or not, if so please take a second and rate it accordingly. Thank you for visiting "fixya" for your washer solution inquiry. good luck going forward. macmarkus :)
Jun 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
CHILD LOCK PROBLEM
hold start button for more than 5 secs will disable child lock. same again to turn back on.
Jan 20, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Jan 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
2,452 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
