With your question, I'm not sure if your looking for another or what your specific needs are but I believe this is it.
http://www.ebay.com/itm/NEW-PULL-START-RED-RECOIL-COVER-11HP-13HP-FITS-HONDA-GX340-GX390-/111147183055?pt=LH_DefaultDomain_0&hash=item19e0e36bcf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
