Music Logo
BedBestys420 Posted on Oct 02, 2013
Keyboard will not turn on - Casio Music
Sam Walker
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 73 Answers
  • Posted on Nov 26, 2013
Sam Walker
Contributor
Level 1:
New Friend:
Cheetah:
Answers
73
Questions
0
Helped
23485
Points
90
If it hasn\'t been dropped or bumped, check the adapter. Work backwards from the keyboard. It doesn\'t take much for the casio adapters to pack a sad. If there\'s an overload in your switchboard, it\'s usually the Casio that packs a sad...everything else is fine, microwave, tv, stereo - just not the casio. Their adapters are garbage and until recently - they\'ve just gotten better
Radio Shack Midi Keyboard MD-4072. How to reset the sound please.
Have you ever changed the internal Lithium Battery. Try the reset here, although it is for a different model. The Keyboard was actually made by Casio and sold with the Radio Shack name on it.
REPLACING THE MEMORY BATTERY
Your keyboard uses one lithium battery to protect some types of data when it is turned off. This battery is installed at the factory,
and lasts up to 5 years. If the keyboard's memory is erased when you turn the keyboard off, take the keyboard to your local Radio Shack store to replace the lithium battery.
RESETTING THE KEYBOARD
Note: Resetting the keyboard clears all information you stored in the keyboard's memory, including the parameter settings, song
sequencer, pattern sequencer, and registration memory. Resetting the keyboard's parameter settings clears only those settings from
the keyboard's memory. To reset the keyboard, turn the power off.
Then hold down ENTER. Reset? appears. Press YES.
https://www.google.com/search?q=Radio+Shack+Midi+Keyboard+MD-4072+reset
Jan 30, 2022 • The Music
Casio ctk-811ex factory reset?
Use this procedure to return all keyboard settings to what they were when you purchased it. Note that this procedure clears all data from memory.
• While holding down the ENTER button, turn on keyboard power. • Reset?
• Press YES to initialize the keyboard or NO to turn on power without changing any settings.
https://archive.org/stream/Casio_CTK-811EX_Service_Manual/Casio_CTK-811EX_Service_Manual_djvu.txt
Oct 23, 2021 • Casio Music
I have a yamaha mo6 keyboard and the touch sensitivity has gone. How can i retrieve it?
If the touch sensitivity on your Yamaha MO6 keyboard has stopped working, there could be several possible causes for this issue. Here are a few steps you can try to troubleshoot the problem:
  1. Check the touch sensitivity setting: Make sure that the touch sensitivity setting on the keyboard is turned on. The touch sensitivity function may have been turned off accidentally or may have been set to a low sensitivity level.
  2. Check the keyboard's firmware: Make sure that the keyboard's firmware is up to date. If the firmware is out of date, it may cause issues with the touch sensitivity function.
  3. Check the keyboard's connections: Make sure that all connections to the keyboard are secure and that there are no loose or damaged cables.
  4. Check the keyboard's internal components: If the keyboard has been subjected to moisture or has been dropped, it is possible that the internal components may be damaged. If you suspect that the touch sensitivity problem is caused by a hardware issue, it may be necessary to have the keyboard inspected by a professional.
If these steps do not resolve the problem, it may be necessary to contact Yamaha customer support for further assistance. They should be able to provide more specific troubleshooting steps based on the make and model of your keyboard.
The ACMP, when chosen, instead of playing chords, is silent. How do I fix this? I have the Yamaha E333 keyboard.
You may have turned down the volume internally.
Carry out a factory reset - Hold down top C key (highest note) whilst turning the keyboard on.
Hopefully this will rest everything and it will work again.
Keyboard does not turn on
Locate the fuse on the keyboard. Possibly blownout
My Yamaha Keyboard turns off when plugged in
What kind of outlet are you plugging into? You should be using a power strip, or power conditioner.
1helpful
My amp becomes distorted when I turn my keyboard up. Both the Master Volume and the CH1 volume knobs are in the middle(12 o'clock). How do I keep my amp from distorting?
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
Keyboard doest work
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
