Right click in your drive select new folder
Place all data files you want to password protect inside your new folder
Right click on your new folder select properties select the sharing tab
Scroll to network and sharing at the bottom
You have many options to password protect many files and folders Windows 7
In XP right click on your folder select properties then click the sharing tab tick the box do you want to make this folder private
A message might appear if you have a password do you want to create a password
Or you might download one or more of these all are free password protection programs
http://download.cnet.com/folder-lock/3000-2092_4-10063343.html
25 MB
http://download.cnet.com/truecrypt/3000-2092_4-10527243.html
http://download.cnet.com/my-lockbox/3000-2144_4-10789387.html
Hope this helps you
Hope this helps
Hope this helps
Hope this helps
When you boot up to the log in
screen type in administrator as user if you cant log in
During the boot up process you
will see on the screen for a short amount of time a certain key to enter set up
press and hold that key to enter set up BIOS scroll to set user password or
supervisor password you can change or remove the password from there if you are
still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable
"live" CD which contains software that allows you to change
paswords repair/restore/diagnostic
almost any computer problem also has a
bios reset tool which remove your password and BIOS password although you will
have to use a computer with an internet connection you will have to burn it to
a disk as an iso then change your firtst boot device to cd During the boot process you will see
on the screen to press a certain key to enter setup Press and hold that key
during the boot up process to enter BIOS the scroll down to advanced bios
features press enter change your first boot device to cd press escape then
press f10 to save to cmos to restart (note after you have removed the password
you must go back and change the first boot device to your hard drive)
Hope this helps
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Dr.Freeware System Utilities which includes
data recovery software, data backup, password reset tools for Windows helps you
to maintain your system. Dr.Freeware is freeware, you can download and use it
for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS,
FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB
Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista
/ 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file
system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local)
account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
