This machine uses a heat-pump to heat up the ir in the drum, it has no heating element.
The problem is likely a failure of the compressor for the heat pump or the (inert) gas in the system has somehow escaped. The machine is most likely beyond a DIY repair.
First you need to make sure you have 220v comeing to the dryer..cause it will run off of 110v,,,but not heat intill it has 220v ..if you have 220v check the thermasate and the heating element
