Vehicle Parts & Accessories Logo
hector alcazar Posted on Oct 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My truck stars but it wont go into gear - Vehicle Parts & Accessories
Philip Armitage
Level 3:
  • Master 437 Answers
  • Posted on Oct 02, 2013
Philip Armitage
Master
Level 3:
Answers
437
Questions
Helped
261098
Points
1503
Your truck uses the signal from your brake switch to activate the shifter lock actuator allowing you gear shifter to come out of park. So first check the brake lights to see if they work. If not then check the fuses that are for the brake or stop lights.
1993 f350 460 cid wont start unless you press gas pedal to the floor
my truck starts right up if I hold the petal to the floor but wont start if I don't hold petal to floor
My 1996 saturn stars up but it wont take off once in gear
Well start by checking transmission fluid, condtion and fluid level, if empty, or burnt and black the transmission is bad, and sound like it is a transmission problem regardless if while in gear does not move.
Car wont go over 40mph
it could be your transmission not ingaging into 3rd or 4th gear. or your plugs or plug wires were damaged in the process.
~Dan Herzberg~
1helpful
Why wont my yamaha 2002 v star **** into gear
Your bike has a bent shift fork judging by your discription. 9a177f5.gif If a fork is bent it will not move the slider gear properly.
Car drops out of gear, stars with 6th lets you
Most probably you need to check the clutch
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
