Question about Toshiba Satellite Pro 6100 Notebook
Endless loop "new hardware found" not installed prop but it is installed and working fine dislogue won't go away
I just installed a printer via usb - it's working fine - but windows XP sp2 on a tosh 6100 won't stop saying "new hard..." and not installed properly - even tho it is already installed and working fine
    Scholar:
  • 74 Answers
Is this an HP printer? If so check the startup tab in msconfig and uncheck the HP webprinting or print to web (something like that). You can also uninstall the printer and reinstall it to see if that fixes it.
Hope this helps
Posted on Apr 30, 2009
6ya staff
SOURCE:
I have problems wtth my printer/to computer won,t print off
Pl. connect a fresh usb cable to the usb socket found at back side of the pc. Check new hardware found at hardware-device manager/Re-install the driver.
Thanks.
Dec 24, 2014 | Office Equipment & Supplies
Printer wont connect to network and now won't print via USB
Dear, Model no not mentioned, If its not printing through net work or USB it might be formatter faulty,,replace it..
Jan 31, 2012 | HP Office Equipment & Supplies
Pleease reinstall printer driver after installin AIO 966 driver
There must be some misunderstanding. Let me give some hints, First, remove the cartridges, unplug the power cable and the usb cable. Now power on your printer and leave it for few minutes. Again, plug/reinsert them and power on (make sure you connect the usb to the printer as well as on the computer usb port). If you get a small window "Found New Hardware Wizard" then insert you cd into the cd/dvd rom. Select "No Not this Time only" from the "Found New Hardware" wizard and click "next" then select "Install from a list or specific location" click "Next", check the "include this location in the search" click "browse" and manually search the driver to you Cd rom directory. After you locate the driver, click "Ok" then "next", the wizard will search and install the driver and click "finish" when it's done. Do let me know if this helps or not.
Jun 01, 2010 | Dell 966 All-In-One InkJet Printer
Connect via wifi
first connect usb cable & power on of your printer
then showing found new hardware than install it by your driver
Apr 05, 2010 | Lexmark X4650 InkJet Printer
My printer will not print...it's saying it's not installed but showing that it is...has worked fine for a year or so but now won't print...I have unistalled and reinstalled the software but it's still the...
Go to Control Pannel and Add remove Programs
and
Uninstall the HP Photosmart 8250 Inkjet Printer Drivers
or
Click start - control pannel - System - Hardware - Device manager - Select the Printer (+) and uninstall the Drivers
then Check by connecting the USB Cable to the Computer without installing the drivers
IF its NOT SHOWING " Found New Hardware Message " - then Please make sure the Printer is on / check replacing the USB Cable - the install the Drivers
If it should show the Found New Hardware Message - then we can deside to install the drivers for the Product
Then download the Updated drivers from HP Photosmart 8250
if above link don't work then
chek : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
According to the Operating System ..
Jan 06, 2010 | HP Photosmart 8250 InkJet Printer
Printer not found when installing
i thing this is usb wire proplem ,or connect the usb to on board usb jack
Dec 31, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Pc don't recogise new hardware
It sounds as if your power supply isn't putting out enough to support so many USB devices on your system. If you have an external USB Hub, do you have a power adapter plugged into it?
Mar 28, 2009 | Computers & Internet
Whentrying to installed any new hardware.PC wont work new items
MY FRIEND THERE IS PROBLEM IN UR USB PORT.PLZ CONTACT TO GOOD DEALER OR WHR U PURCHASED UR LAPTOP
Mar 28, 2009 | Acer Aspire 5101WLMi Notebook
Printer driver not working
Hi there, i dont know if this is of any relevence however, i have just spent the whole afternoon trying to install my new printer, every time i installed my disk a little icon popped up saying usb didnt recognise the device, despite endless frustration i did it another way, If your printer is a usb connection then before inserting the disk connect the printer to the computer and switch on, this then brings up the wizzard which should help you install, if this doesnt work...trust me it took me ages, try different usb ports, i finally found one that picked up the printer, after it detected the device i was then able to continue with instalation via the disk and wohoo many hours later i have a printer, unfortunatley i have now run out of paper doh!!! i hope this helps someone :-)
Mar 03, 2008 | Computers & Internet
HP 5550. Stuck in install loop
uninstall previous printer driver and resintall again the cd driver
Feb 01, 2008 | HP DeskJet 5550 InkJet Printer
Toshiba Satellite Pro 6100 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
