Based on the information you provided, it seems like the Kenwood TK-2000 radios you have may have been programmed with the wrong band split. The TK-2000 is available in both VHF and UHF frequency ranges, and it's possible that the radios you have are actually UHF models, despite being listed as VHF frequencies when you read the radios.
To check if your radios are UHF or VHF, look for a label on the back of the radio that specifies the frequency range. If it says UHF, then the radios can only accept frequencies in the 400-440 MHz range. If it says VHF, then the radios should be able to accept frequencies in the VHF frequency range.
If you've confirmed that the radios are indeed VHF models, then it's possible that the band split settings may need to be adjusted in the programming software to match the specific VHF frequencies you're trying to program. I recommend checking the manual for your programming software to ensure that you have selected the correct band split settings before programming the radios. If you're still having issues, it may be helpful to contact Kenwood customer support for further assistance.
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats the case you will need an Icom that will do UHF freqs.
The Bellsouth 2231 is a FRS VHF I couldn´t find if thi Bell south 1007 is FRS in UHF or VHF if you have this informtion compair them if both are in the same band VHF or UHF both radios can communicate to each other
