top
CODE ALARM
SYSTEM
information
is always subject to change and correction
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
Battery
GP-23A
Lock: Left button will lock
all doors. Double chirp indicates locked.
Unlock: Right button will unlock
driver's door only. Hold unlock button app 6 seconds, it will unlock all
doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the
alarm was triggered.
Panic. Press both buttons to activate
emergency honk and flashing lights.
Valet mode: With optional alarm
only
Press the red alarm button on the left of the steering wheel.
The light will quickly double flash. To re-set back to normal mode, press
the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's
battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button
once OR turn the ignition switch to the “ON” position and press programming
button for one second (see below).
The vehicle interior (courtesy) light
and door open warning light (DOOR AJAR indicator) will then illuminate
for 60 seconds when the ignition is turned off, or until the doors are
locked with the remote transmitter. Yes, the dashboard instrument panel
lights will flash when the parking lights flash.
Programming or Overriding the Alarm
when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in
(see diagram, button under dashboard)
After 15 seconds the the door locks will
cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to
be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming
button under dashboard and turning key to off.
Code
Alarm Programming Button is under dashboard on the kick panel by the driver's
left knee, left of the steering column. If you can't find it, it might
still be tucked up in the wiring harness higher up in that same general
area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming
remotes or if the battery was disconnected and the lights are flashing.
top
