SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
SOURCE: I have a Goldstar Dehumidifier DH504ELY7 that
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
SOURCE: goldstar dehumidifier dh305t7
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=DH504ELY6&matchedModelCode=NOT_MATCHED&searchEngineModelCode=DH504ELY6&initialTab=documents&targetPage=support-product-profile#
Only available for DjVu reader (download link on LG site). You'll need to download and install the plugin then close and relaunch your browser. I was only able to get it to work in IE in the end with Firefox and Chrome not working. IE objected I had to "allow" the plugin to run then once again close and relaunch the browser then it finally worked. Good Luck!
SOURCE: i need a bucket switch
My best suggestion is either www.appliancefactoryparts.com .com or Sears Parts Central. The part you're looking for is pretty generic.
Hope this helped you., Scott.
There
Here
Dehumidifier
heatman101
