Televison & Video Logo
Anonymous Posted on Oct 01, 2013
Kingston microsd using usb adapter is not recognized on laptop (vista premium 32bit) and on hp desktop (win 7)
Kingston microsd - and even other micro SD makes 64Gb) using usb adapter is not recognized on laptop (vista premium 32bit) and on hp desktop (win 7). But it is recognized when using an SD adapter on all same computers.
Sebe Christian
Level 2:
Sergeant:
  • Expert 401 Answers
  • Posted on Oct 20, 2013
Sebe Christian
Expert
Level 2:
Sergeant:
Answers
401
Questions
8
Helped
72860
Points
960
Sometimes a little balloon will pop up, try clicking on it. Most times though, it just goes on ahead and installs whatever driver it feels like is needed. Also, try going into "Devices & Printers", right-click on your device, and click "Troubleshoot."
Russ Hill
Level 3:
  • Televison & ... Master 4,057 Answers
  • Posted on Oct 02, 2013
 Russ Hill
Level 3:
Answers
4057
Questions
10
Helped
1177426
Points
12696
Have you checked the drivers for the usb adapter. plug it in and go to my devises and up date driver see if that fixed it. vista software may have a problem as they are not updating there software files. but win7 is fine has same filing as xp.
2 Related Answers
Anonymous
  • 617 Answers
  • Posted on Feb 05, 2010
SOURCE: WinTV HVR-1600 not working when I upgraded from Vista to Win 7
get drivers for win 7 for card
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Sep 01, 2011
SOURCE: SABRENT tv usb I just
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
if these driver packages aren
Hp pavilion dv2000 internal micro phone drivers free download
I dont know exact model of your dv2000 hp laptop is, there is many versions of them (as an example HP Pavilion dv2401tu).
Microphone drivers are part of the sound driver package. Suggest if you are running 7, go for the vista drivers. 7 32bit, vista 32bit drivers. 7 64bit, vista 64bit drivers.
Windows update is another option for finding sound drivers for the microphone.
The pc will not detect the wireless card. Already updated driver, BIOS, and tried a new card. I did update from Vista to 7 Professional.
Did the wireless card ever work? If it did work I would check to see if there's a physical switch on the laptop. Try switching it off then on. I would also try a different driver. Sometimes I've used an older or newer driver to get a wireless card to work. So if the driver that's installed is for Vista I would try obtaining one for Win 7. You could also try a wireless driver fro XP 64bit. I've found that some Manufacture's Web sites have several drivers listed for "network card" you could have a installed a "network card driver from HP's site but it might not be the correct version or manufacturer. From HP's site I don't see Win7 listed as an option. So you could have an incompatible driver installed. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3376893
One other item to check. If you had Vista 32bit installed originally then went to Win 7 64bit you could try the Vista 64bit driver.
If all else fails you could purchase a USB wireless device to make your laptop wireless again. I picked up a Trendent
http://www.techpartswarehouse.com/product/TN-TBW107UB-TRENDnet-Micro-Bluetooth-USB-Adapter-5600.cfm?sid=google&gclid=COGH5NyNv7oCFe1aMgod93wAuA
Let me know if you have any other questions?
Brian
Is my hp photosmart m537-001 compatible with kingston micro sd adapter?
Make sure you're using a microSD card, 2GB and smaller, and not a higher-capacity microSDHC card.
7helpful
2answers
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
2answers
32bit vista to 64bit win7
your recovery manager files should be on drive D or other partition. if not then its gone. but the operating system cd that goes with your laptop is still better than the factory default anyway but the thing is, youll need the cd everytime you want to reformat.
if i where you, il go for 32bit win 7 since your computer used to be a 32 bit vista. no worries about making the most out of your computer since win 7 eats less than vista anyway. and go for 32 bit since your laptop is made for 32 bit.
1helpful
My windows not shwoing whole RAM size
What you are seeing is correct. You have 4GB of physical RAM installed in the computer and it is being recognized properly by the BIOS. A 32-bit operating system can only address approximately 3.5GB of RAM. Vista may be rounding the number down to 3GB or if you are using on-board video, some of the RAM is being allocated for use by the video circuitry and is not reported as system memory. To see all of the installed RAM in your operaing system, you need to upgrade to a 64-bit version of Vista.
1helpful
System crashes and i have to reformat after installing msn premium software on new 64 bit vista laptop
you can downgrade to 32bit. you would have to reinstall windows using a 32bit cd. i would recommend it you wont see much of a difference. all programs where originally made for 32 bit. the only difference between the two is that 64bit supports more ram. like xp pro; 32bit will recognize 3.25gb as ram even if you have 4gb installed but other than that not much difference. personally i dont like any 64bit systems nor vista... but with 32bit you will be able to run a wider range of programs with no problem
4helpful
5answers
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
