Karcher MAGIC SING ET18K (ACCESSORIES) Logo
A
Anonymous Posted on Oct 01, 2013
How do i connect magic sing et18k to computer?
Magic Sing ET19KV On connecting Magic Sing through RCA Cable, get buzz sound on my speakers Have chked on diff TV's and replaced the RCA cable.The Video is clear, but getting buzz on speaker
Most buzzes are caused by one of two things: "DIRTY" power or a lifted\non-existent ground. Allow me to explain;
"DIRTY" power is just that. It comes in and carries a lot of static with it. Most newer systems have filters built in on the power side of the main board. The fix? Try running your Magic Sing from a wall socket that doesn't have anything else pulling from that particular circuit. You should also invest in a GOOD power strip and not one that cost $5-$10 bucks. All these are good for is getting power to multiple products simultaneously, AND they don't have the resistors and filters to give you a constant 120v AC.
Monster Cable Co. was a very sought after item up to the point to where Radio Shack no longer carried their products.
If you really want to get your money's worth out of the instruments you buy, don't slack on the power strip. This will be the most costly mistake ANYONE can make.
Here is an article that explains what I did and gives you answers on how to fix this issue.
Hope this helps. Dirty Power What It Is and Why You Need to Clean It Up Schneider Electric...
I got behringer 802 audio mixer and a mic..what else do i need to start singing..
Please verify if your computer has a sound card. You will need a provision on your computer for audio input. Let me know.
I have a Behringer B1 Microphone and a Behringer 1202 Mixer. I want to know how to connect both of these to my Yamaha Home Theater receiver so that I can sing karaokes from the computer, Please help
You'll need to connect both your PC and the Mic to the mixer, you'll need phantom power switched on at the mixer for the mic to work, you then take the two track out to the Aux input on the receiver.
1helpful
2answers
Instruction booklets on machine
Many of the Singing Machine Karaoke system manuals are available on the company's support site: http://www.singingmachine.com/support/instruction_manual.php . The direct link to the STVG-1009 manual is http://www.singingmachine.com/download/Instruction_Manual/2010/CDG/STVG-1009/STVG-1009%20IM%20E01%20(SMC%20US).pdf .
I hope this helps.
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Where is the pre-programmed song chip located and can I purchase an English main chip and swap it out? I inadvertently purchased the Spanish version and I don't want to return the entire unit, I just want...
The chip MAY not be a plug in type, but a surface mounted one that is burned with the sound at the factory. I would NOT attempt to change the preprogrammed chip. You will be out the shipping charge, but that is better than to damage the unit. Otherwise, purchase the add on chips in the language you want and forget about the internal ones.
I have enter magic sing i put it on a wrong voltage then the power supply regulator got burn how can i replace it. where can i buy iC76A and how much
It is likely soldered into the circuit board. It may be any of several part numbers such as 7805.
Try to read ANY number you can off the IC itself... the last two digits are the voltage... 7805, 7812, 7815 are common ones... There often is a production lot number... see if you can find the number ang et back to me as email.
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Top Karcher Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Karcher Music Expert? Answer questions, earn points and help others
